Help with manual
spdracr39
I'm just trying to find out which manual to look for. I have a 2008 mercruiser 5.0 mpi s/n 1ao51639 with alpha one gen II drive. I have a copy of manual #31 but i don't think this is the latest manual. Can anyone tell me if there is for sure a newer one and the manual number? A link would be nice too but I'm not sure that's available yet.
Fun Times
Re: Help with manual
Your looking for 90-864260T00 - SERVICE MANUAL #31 V8 ENGINES 5.0, 5.7, 6.2, it's not available for free online.
achris
More fish than mountain goat
What specifically are you looking for? The reason I ask is because there are 4 other manuals you would need to have all the manuals that cover you package.
You need the drive manual, #14
The MPI diagnostics manual, #36
The fuel system manual, #40
The exhaust system manual, #37
Cheers,
Chris.......
Fun Times
The MPI diagnostics manual, #36 ECM 555 Diagnostics
Cheers,
Chris.......
37 NLA ? Dry Joint Exhaust System (merged into SM 31 August 2009)
40 NLA ? Engines: Gen III Cool Fuel (merged into SM 30, August 2011; SM31 August 2009)
41 866202 Dec 2004
Engines: TKS Turn Key Start (merged into SM 46, August 2011) , supplement to SM 25
4.3L SN 0W300013? 2004? 8M0050319
Manual Outline
1 - Important Information
A - General Information
B - Maintenance
C - Troubleshooting
D - California Emissions Information
2 - Removal and Installation
A - MCM Models
B - MIE Models
3 - Engine
A - Engine Mechanical
4 - Electrical System
A - Starting System
B - Carbureted Ignition System
C - MPI Ignition System
D - Charging System
E - Instrumentation
5 - Fuel System
A - Carbureted Fuel System
B - TKS Carburetor
C - MPI Fuel System Excluding Scorpion Models
D - Scorpion Fuel System
E - Gen III Cool Fuel
F - Diagnostics
6 - Cooling System
A - All Models
B - Seawater Cooled Models
C - Closed Cooled Models
D - Water Flow Diagrams
7 - Exhaust System
A - Manifolds, Elbows. and Risers for Wet Joint
B - Dry Joint Identification
C - Manifolds and Elbows with Dry Joint
D - Cold Risers with Dry Joint
E - Warm Risers with Dry Joint
F - Collectors
8 - Drives
A - Velvet Drive In-Line and V-Drive Transmission
B - Velvet Drive 5000 Series Transmission
C - ZF/Hurth 63 and 80 Series Transmission
D - ZF Marine/Hurth 45C In-Line Transmission
P.S, Sorry Chris but it even bigger then the other.;)
achris
Thanks FT... I need someone to keep me in line... :D :D :p
spdracr39
Wow that's so complicated I still don't know what I need. and to make it worse I do know that manual #36 ECM diagnostics is also NLA. I just wanna know how to find all the drain plugs and basic preventative maintenance. I can figure it out without the books but I like to have them so I can see if the service department is trying to get to me when I have work done.
Don S
Go to the link below and order the owners manual. They cover draining the cooling system, and has maintenance charts. With all the different draining systems Merc has developed, it's confusing for everyone.
https://webapps.brunswick.com/litreq/navigate.do
spdracr39
Thanks but the link didn't work :(
