- Joined
- Mar 8, 2009
- 44,275
Re: help with mercruiser 5.0L !
slothman I do believe you have two issues and one is compounding the other. You may have fixed the fuel issue by replacing the filter, time will tell.
The next is spark and goop or grease should not be found. Your coil has cracked and the oil inside is leaking out and needs replacing. Once you get the coil replaced we may be able to determine what other issues are lurking and figure them out.
Like dad use to say, we all got to hang in their like a hair in a biscut
I replaced the separator. Filled it to the top with gas. Installed it and cranked her over. She didn't start. I pulled the separator again, and a little bit of the gas was gone. I THINK the manual fuel pump is doing its job, but I don't know if it's building adequate pressure.
I also cleaned the coil wire and cleaned the inside of the coil itself. It was goopy and full of grease. I am not sure if this is how they come from the factory. But that crap was everywhere. I pulled the wire from the coil side and left it sitting on top of the coil, and cranked her over. I didn't see a single spark, nor did I hearing any pop pop. MAYBE it's a spark issue after all, but I am still perplexed. I will have the new coil tomorrow.
