help with model number please
coolbri70
i bought this motor and it runs good no problem, IMG_20130105_153128.jpgIMG_20130105_153541.jpgIMG_20130105_153421.jpg the po told me it was a 94 model short shaft 9.9 upgraded to 15hp and electric start, i wanted to look at some parts diagrams to get familiar with my motor, there seems to be some gap in the parts lists, did i get some odd year? i went down to get the model number off the motor and the sticker had been torn off, maybe this stamp will helpIMG_20130105_224746.jpg hope someone can shed some light, parts seem to be listed till 93 and then from 95. why no 94:confused: the number is G357435
coolbri70
Re: help with model number please
after a little research i see that 94 was the last year of the 2 stroke? why do parts lists run to 93? i read of a similar motor it was a E10RERB could that be it?
coolbri70
? Model E10EERB
? Model E10ELERB
? Model E10RELERB
? Model E10RERB
? Model E10RLERB
? Model E10SELERB
? Model J10EERB
? Model J10ELERB
? Model J10RELERB
? Model J10RERB
? Model J10RLERB
? Model J10SELERB
got to be one of these but which one:confused:
mark1961
Ensign
Hint.....your motor has both rope and electric start so the model number will have "RE" designation......that should narrow your list down a little.
coolbri70
the motor began life pull start the electric was added i was told
mark1961
Ensign
I see......then do the reverse of what i stated previously......if the motor is a longshaft, eliminate anything on your list that has "RE" before "L"and anything that does not have "R" after "10".
mark1961
Ensign
So what are we left with?
E10RERB or E10RLERB......depending on the shaft length of the motor.
coolbri70
thanks, it's a short shaft so must be the E10RERB, is there a sereal number elsewhere on the motor?
coolbri70
just wondering so i could write it down in case of theft, maybe i can engrave it with something.
coolbri70
ok, i was worried that the tag was gone and i had no serial number, then after some searching i read that it's stamped in the core plug of the engine block. so i guess thats my number in post #1:confused:
