help with montgomarywards 7hp
offtheshore
hi can someoen tell me what the oil ratio is for this modle and does it have reverse..... modle k700 1107a
seriel 595 900
type 6027270r
it is air cooled...... it is a 7 hp
would this push a 14' boat
thanks
CATransplant
Re: help with montgomarywards 7hp
Hi,
Your outboard was made 1973, by Clinton, for MW. The actual model number on the outboard would start with KTV. If you can find that, I can tell you the exact year for sure, but 1973 was the only year the K700 Clinton engine was used in a MW outboard.
Fuel:eek:il ratio for other Clinton-based engines in that age range was 24:1, and that should be safe for yours, although I do not have the specifics for your model. Use chainsaw oil or TCW3 outboard oil. Either one will work.
It has no reverse.
Will it push a 14' boat? Sure. Will it plane a 14' boat? Probably not. Those single-cylinder air-cooled outboards from that era generally don't do as well as similar sizes of 2-cylinder water-cooled outboards.
