doggfather69
- Joined
- Jul 25, 2011
- 52
I need to replace my prop. I looked all over it and cant fint any numbers or spec. I would think from all the reading I have done that a 14x18 will work for me but want to ask a few pros. I have only had this boat for a year, never had one before this. My best friend was killed in iraq and his parents gave it to me so it means alot to my family to keep this thing running. I hit a rock and jacked up one of my blades.
1979 18.5 foot bayliner with a aq120/270
I dont know much else but could use some tips on fixing it up and stuff. Any help about anything it is welcome.
I do know the boat is a tri hull and has open seating in the from so its not a cutty cab. So the boat probably seats 8 without a problem or crowding. What I use the boat for is cruising up and down the rivers here in Pittsburgh and pulling my kids on a tube. I would like to be able to pull someone on skis if its possible. With that info can you help?
Sorry if you are seeing this twice because I did post this in the prop forum. I just figured that I would put it here since its the bayliner forum.
