Help with my fleetwin PLEASE
dfoss
Hey guys I have a 55, 56, or 57 fleetwin. I was hoping someone knew what year it might be from the serial #. It is a 7.5hp serial # is 7524-10127. Also it is a short shaft and I put it on a boat it was too small for. Now it runs but doesnt pee any water. Is it the impeller or water pump? I have a guy that can help me fix it but where can I get the impeller for it or water pump? any help would be great thanks.
Donavon
tashasdaddy
Re: Help with my fleetwin PLEASE
1958 7.5 hp fuel oil mix 24 to 1. OEM part # for the water pump rebuild kit 391391 superceded to new number 763758. i check iboats for it, did not find. dealer, laingsoutboards.com or ishopmarine.com around $40.00 + shipping.
JB
Those first 4 digits, 7524, are the model number, Donovan.
That is a 1958 7.5.
Is this a new-to-you engine? I don't recall telltales on those engines.
If you don't find impellers or water pump kits here on iboats, you can try NAPA auto parts stores or a JohnnyRude dealer.
Others will come along with other suggestions.
JB
Dang! I need to learn to type faster. :(
samo_ott
No kidding. TD had it in 9 minutes! I think he has it wired to a pager or something!
tashasdaddy
just got lucky guys. then i edited the part numbers.
jay_merrill
The motor doesn't have a telltale but water should be flowing out of the exhaust port on the back of the midsection.
dfoss
Hey you guys are good, thank you so much. If i can get the part at napa that will be even better. Once again thanks for the help I'll let you know how things end up. Hopfully this jon boat I have will get back on the water.
Donavon
samo_ott
And make sure the water pump is under water when testing, running it out of the water is not good!
