Help with new Lenco Trim Tab Switch
I am asking if this will work? It is comical but I am determined to get this right!
Thanks again,
Brian
No cutting and splicing needed. Only wiring it correctly per the schematic.
You have 2 wires swapped
So pull the switches back out. Go thru the wiring and make it match the schematic
Lancerdad34
It is really hard getting the panel out without possibly damaging the switch. All I am asking is there any issue switching the wires in the stern. I have a good 8 inches extra there.
Thanks,
Brian
dingbat
Thanks,
Brian
No problem whatsoever but the next owner will not be happy if he has to troubleshoot a problem in the future
Lancerdad34
Thanks for the reply! Good point if I ever sell I will let the new owner know!
Lancerdad34
Update!
Well I do not feel so bad after all! When I looked the wires back at the port trim tab they had them reversed! So I did wire the switch the right way. I will never be an electrician but feel more comfortable doing **** like this now. Both trim tabs working the way the should now. Have a good boating summer!
Thanks,
Brian in MI
