Help with new merc
Dmaxx85
Hello there
So I got rid of my Volvo Penta and bought. 1997 Mariah with a 4.3 lx alpha one .
So I this motor is new to me ! So any info on this motor would be great!
Also am looking to do a tune up , so any recommendations on plugs wires caps and rotors would be great .also should get a fuel water separator.
Also one more question
Is my new motor a vortec?
Thanks for any help
Travis
Don S
Re: Help with new merc
The first thing you need to do with your new engine and drive, is to get the Merc serial numbers for both and post them here so we can ID things for you. Those numbers are used for everything, so keep them handy.
achris
More fish than mountain goat
Service manuals.
Drive.
I'll need an engine serial number to get the right engine manual. I can also use that number to determine wheter it's a vortec.
Spark plugs, again the serial number is needed, as for plug wires, any high quality silicone lead set from a local car parts shop will do the job. The rotor and cap will need to be marine grade.
The engine should already have a water sep filter on the starboard side, at the front, just under the exhaust manifold.
Chris......
Dmaxx85
Ok guys finally got a chance to get up to the boat and get the number. Engine serial Number is: 0K170684........ Transom serial number is: 0K220751......... Drive Serial Number 0K246170......... Any information on this motor and tune up help would be great! also still wondering if its a vortec????? Yes this motor does have a fuel water seperator just wondering if this should be replaced?
Thanks for your time!
Don S
No, it's not a Vortec engine. You can tell by looking at the intake manifold. You engine should have 12 bolts holding the intake on. The Vortec engines had 8.
The valve covers are also way different. The Vortec are a lot wider, are composit not steel and they say Vortec on them.
The manual you need is here, Manual #18
Yes, the fuel filter element should be replaced. Yearly. and when you remove the old filter, pour it into a clear container and check for water.
Dmaxx85
Ok thanks a lot! So I got the number off my current fuel filter and its made by aqua power and the number is 6031 just wondering how this would match up to a Sierra fuel filter?????? Also wondering what the correct spark plug is supposed to be in this motor????
