Fishahollik
Thread starter- Joined
- Feb 17, 2012
- 17
This is a 1985 or 86 25 Hp evinrude thru hub exhaust motor without shear pins mounted on a 16' flat bottom. I recently had the boat out and ran into a sandbar going a little over idle speed. I held the motor up to keep prop out of the sand until water was deep again. Began to accelerate to full throttle and engine would over rev like the prop is cavitating. I slowed down, checked for weeds, debris etc... Prop is clean. I assumed spun hub on prop. I changed to a spare prop, same thing happened. Could both hubs be spun? Possible but unlikely. What else could cause this?
