help with pump
therigwelder
i took my lower unit down today,i didnt remove the prop as i couldnt get it off?is there a reason why the prop needs to come off? as i suspected the impeller was missing all but one blade and it looks like it disintegrated into pieces. i see alot of small pieces of impeller lodged in the area where i would attach the motor flush muff.my problem is i dont know how to disassemble the pump. i removed the top of the pump but does that long shaft have to come out as well or can everything slide over that shaft? the motor is a 1974 merc 850.also there seems to be some small burrs on the shaft preventing the old impeller removal. i am assuming i can pass a file or some emery cloth on the shaft to remove the burrs? ive already purchased the water pump kit and would like to go fishin so thanks for help
jimg984
Re: help with pump
everything comes up and off the shaft, there is a slot between the impeller and shaft, its called a keyway with a key, this makes the shaft turn the impeller, sometimes its hard to break loose, be sure not to lose it and put it back with new impeller GL
