Help With Replacing Deck Please
BOATINGmatt
i HAVE A WELLCRAFT v-20, WHICH I AM REPLACING THE DECK DUE TO ROT..i AM RE-PLYWOODING THE WHOLE DECK ..RESIN CLOTH ECT...ON THE DECK THERE ARE TWO CIRCULAR ACCESS PANNELS FOR THE GAS TANK, AND A DEEP WELL JUST BEFOR THE DOOR TO THE CABIN..THE WELL HAS A PLYWOOD TOP. oBVIOUSLY THE ACCESS PANNELS HAVE TO BE PUT IN THE NEW FLOOR BUT CAN I PLYWOOD OVER THE WELL. tHE WELL IS REMOVEABLE AND ALL THAT IS UNDERNEATH IS A PIECE OF 3/4 PVC PIPE THAT SEEMS TO RUN FROM THE BOTTOM OF THE BOAT BENEATH THE WELL TO PARTS UNKNOWN..( I AM ONLY REPLACING THE FRONT PART OF THE DECK...CAN I REMOVE THE WELL INSER AND JUST PLYWOOD OVER IT?? WHAT IS THAT PCV PIPE?? COULD IT BE A FEED FOR A BAIT WELL AND DO I NEED TO CLOSE IT UP?? I CAN FIGURE IT OUT..ALSO THE RECESS IN THE FLOOR JUST AFTER ENTERING THE CABIN..CAN IT TO BE PLYWOODED OVER..ALL THAT IS IN THERS IS NASTY CARPET ..AND IT IS COVERED BY A PLYWOOD CARPET REMOVABLE TOP..THANK YOU SO MUCH.
Bob_VT
Re: Help With Replacing Deck Please
Wow ...... first time on a forum? All capitol letters is considered rude and shouting.
I will move this to the proper forum in Resoration.
__________________
a70eliminator
I'll bet the pvc tubes are drains, I would keep the well there.
scipper77
Pictures would help us to help you.
CheapboatKev
wow..my eyes were bleeding..
I wasn't about to fix the all caps, however a little punctuation went a long way toward making your post READABLE. (yes, that is shouting..:mad:)
I have a Wellcraft v-20, WHICH I AM REPLACING THE DECK DUE TO ROT.
THE WELL HAS A PLYWOOD TOP. oBVIOUSLY THE ACCESS PANNELS HAVE TO BE PUT IN THE NEW FLOOR, BUT CAN I PLYWOOD OVER THE WELL?
THE WELL IS REMOVEABLE AND ALL THAT IS UNDERNEATH IS A PIECE OF 3/4 PVC PIPE THAT SEEMS TO RUN FROM THE BOTTOM OF THE BOAT BENEATH THE WELL TO PARTS UNKNOWN..( I AM ONLY REPLACING THE FRONT PART OF THE DECK)
...CAN I REMOVE THE WELL INSERT AND JUST PLYWOOD OVER IT??
ALSO THE RECESS IN THE FLOOR JUST AFTER ENTERING THE CABIN, CAN IT TO BE PLYWOODED OVER?
THANK YOU SO MUCH.
BOATINGmatt
WOW..ok so i took a few lumps there and i guess im a terrible typist..and sorry about the caps..anyway thanks for the help...
