Help with serpentine belt part number on Mercruiser 4.3L
lou23
I need a new serpentine belt for a Mercruiser 4.3L. The info I have is S/N OM346613 Model# 4211025PS and it has a description of 4.3L Alpha/Bravo 262 cid GEN+
I believe the part is 57-865615Q03 but I’m trying to verify that before I order one.
Thanks
Bt Doctur
If its not broken remove it and size it at a auto parts shop, Not a marine belt just an ordinary Dayco
achris
More fish than mountain goat
If it looks like this...
Click image for larger version  Name:	beltV6.JPG Views:	1 Size:	42.6 KB ID:	10889234
Then it's a standard Gates belt, 6PK1930.
Thanks
That part number is for a Bravo engine (with an engine mounted sea water pump), but your serial number comes up as an Alpha... (same as the one in the above photo)
Fun Times
Serpentine belt for a Mercruiser 4.3L. S/N 0M346613 Model# 4211025PS... I believe the part is 57-865615Q03 but I’m trying to verify that before I order one.
The Mercruiser part number that would fit your engine from factory would be 57-865615Q04 .
BELT, Serpentine (#57-865615Q04)
Comment: (Standard Cooling) (Alpha) (Power Steering)
Supersedes: 57-865615004, 57-863876 4
The exception would be if your engine was added a Mercruiser sea-water-pump mounted to the engine for say a closed cooling system using antifreeze or other means of cooling per se then your found part number ending in Q03 would be needed.
Bt Doctur
Serpentine Belt 57-865615Q03 76 Inches 1941 mm length Fits 2001 and newer MCM V-6 & V-8 (305, 350 & 377 cid) Alpha engines with closed cooling Bravo engines with standard cooling (S/N 0M320025 and above)
