Help with timing 150 johnson
kwt600
I have an 02 150 that we just finished rebuilding. My question is where do I set the timing for the initial start up? The book calls for 6 degrees ATDC idle and 20 max rpm.
Thanks, Ryan
nymack66
Re: Help with timing 150 johnson
Yea Pick up timing ...Check the FAQ its covered pay no mind to the pick up timing for now its overrated anyways...WOT is what matters period...IMHO of course ...
kwt600
I'm not sure what you mean by pick up timing all i need to know is where to set it before i fire it for the first time. Should I set it at the idle or max timing?
