Help With Trailer Brakes Please
Chef Shawn
27 ft Imperial, dual axle trailer. Previous owner said brakes where failing on trailer, but pointed out the hitch receiver was the problem. I pulled off one side of tires and the drum pads look good, imagine the other side will be good as well. I am not familiar with this hitch style, am I missing parts? Why is the lever locked back? What do I need to do to fix this? Any help appreciated.
Brakes are not electric, standard 4 point harness.
Thanks
Lou C
Re: Help With Trailer Brakes Please
I'd say you're missing...a brake line....and a break away cable! No wonder the brakes don't work. Look to see if the brake line is under the Master cylinder....but I bet you'll be replacing that actuator, possibly the lines and everything else....even if the backing plates look good, the lines could be rusted and full of rusty brake fluid. Start all over and put brakes on both axles if you are going to tow that thing anywhere. That way you know you are starting out right. I put a brake system on my old '94 Load Rite back in '04 and all I've had to do is replace the wheel cylinders a couple of times (salt water use).
bruceb58
You will likely need a new master cylinder
Replacement Master Cylinder Assembly for Titan Model 10 and Model 20 Brake Actuators - Drum Titan Accessories and Parts T2374600
and possibly wheel cylinders
etrailer.com - Products wheel cylinders
along with new brake lines.
If the drum brakes themselves are in very bad shape, sometimes its better to replace the whole backing plate with a new assembly.
Demco Hydraulic Drum Brake Assembly - Single Servo - Galvanized - 12" - Right Hand - 7,000 lbs Demco Trailer Brakes 23510
Whoever welded that bracket behind the master cylinder for the tongue jack did you you no favors. Can't remember if the master cylinder needs to come out the back or not. You may be able to get it out the front but you will have to remove the sliding portion of the coupler.
Here is a diagram of your coupler:
http://www.trailers-nem.com/items.asp?Cc=BRK-DICO_10_20
Lever is supposed to be in that position. That is the break away lever that will get pulled by the safety cable if you ever lose your trailer off your hitch. That lever applys the brakes by moving the master cylinder.
Thalasso
This is where the brake line comes out. You don't have one
smokeonthewater
Basically you are going to need the entire surge brake system... Your wheel cylinders and master cylinder will all be junk from water intrusion due to no brake line... Mine was the same way... Part of the reason I went to electric brakes was because it was 1/3 the cost of replacing all the surge stuff.. the other reason is that I like the electrics better....
bruceb58
$102 for the Master cylinder.
$100 for wheel cylinders.
$100 for brake line kit.
Switching to electric will be more if you need to buy drums and a brake controller.
Starcraft5834
Easternmarine.com trailerpartssuperstore... take your pick
Chef Shawn
Thanks a lot for the information, everyone. Have to go through the trailer with a little more detail and figure out what I want to do.
smokeonthewater
$278 is what it cost me for the entire conversion but that was for all new brakes on all 4 wheels.... most drums will be fine for both styles but look to make sure ... inner face needs to be flat without any rivets.... I would suspect that a closer inspection of his brakes show than he needs more than just wheel cylinders behind the drums
It was gonna be over $700 to replace my surge components and I already had new brake line.
true though I already had a brake controller... IMHO no truck should be without one lol
a basic controller can be has for as little as $40 though I suggest spending at least $70 on a better one with at inertia sensing.
phillyg
If the drums and hubs are still good you may still have to replace everything else from the actuator to the wheel cylinders. I wouldn't give up on the wheel cylinders without a thorough inspection. The good news is that brake parts are relatively inexpensive.
bruceb58
A Tekonsha P3 is going to run $120.
If I was switching to electric brakes, I would be replacing the drums that are specified for electric brakes.
smokeonthewater
that's true...
looking at only new stuff on ebay:
a Curt venturer is $37 (timer operated) (I hate these)
a tekenosha voyager is $56 (pendulum sensor)
If you want used you can get even better for less
bruceb58
that's true...
Welcome to the Stone Age of brake controllers!
smokeonthewater
nooo the stone age was the best ever... had a T into the brake line.....
But yeah... that's why I said I suggest spending at least $70 on a better one..... mine is a pendulum sensor tho and I have no complaints.
