Help with transom mount trolling motor
idunk
I have a Bayliner Capri Bowrider Outboard and was curious if anyone has ever seen a bracket that can be attached to the stern for a transom mounted trolling motor? I really do not want a bow mount, even though I have a quick release Minn-Kota bracket. Seems that bracket has some sharp edges on it, not good for the skin. Besides the transom mounted trollers are way cheaper than bowmounts. Am I all wet in my thinking? Any suggestions? Thanks!
This_lil_fishy
Re: Help with transom mount trolling motor
I've not seen one, but some 1/4" thick aluminum plate could be fabbed up pretty quick to do the job. I thought about doing the same, but have not seen any transom mounts with remote controls....
Ian
Jeff-in-PA
I put a bow mount on my 18' Celebrity I/O
You could also turn the mounting plate so the motor would store at an agle if you need the space up front. It's only my wife and I ( plus the dog ) in the boat.
I made up three stainless steel tubes with washers welded on the bottom to mount to the front. I also have teflon washers to protect the paint. Three 5/16" stainless steel bolts hold it in place.
Jeff
idunk
Thanks for your suggestions. By the way Jeff, cool boat and great scenery! I have to drive many hours to find decent water!
