Lancer76
Thread starter- Joined
- Jul 23, 2017
- 121
1976 Lancer with Mercruiser 233, S/N 4518524. I purchased this boat last year and tracked down a cooling problem, which I resolved. It was running great until I decided this year the the dwell angle was a bit too large. Well, I adjusted the points and the timing to 10* BTDC, but I had a heck of a time starting the engine when it was fully warmed. Even worse was getting into gear from neutral - it will die. The battery and starter are fine and the boat cranks well. I can start it, but I have to have the throttle opened a bit and when I back it down to put in to gear, it dies. Also, I noticed today that when under way, the motor ran a little rough, as if a cylinder was missing. However, no apparent backfires. Did not have this issue prior to my messing around to 'improve' the situation.
As I said, I have checked the point gap and the timing. I have also changed the fuel/water filter (not the one on the carb though). I also checked that all pistons were firing - I did this with my timing light, so it's possible that I have a cracked plug insulator.
My plan is to pull all the plugs and check them. I will also check compression. I will change the points as well.
I am wondering about rebuilding the carb. It is new to me, and it sat for a while before I got the boat. The carb is a Rochester '2 Jet'. It is stamped on the top with "CM' or "GM'. Looking at my Selco guide, it looks similar to what is referred to as the Rochester 2GC (i.e. two idle adjustment needles). At a minimum, I will replace the filter in that carb.
Am I going down the right road? Would you suggest something different? Is the carb a 2GC? And can you point me toward a better manual online. the Selco is OK, but I wouldn't mind a second source. Thanks a lot.
