Help with vibration from 1400-3500 RPM
dubs283
You can add shims under the mounts as needed but this could be an indication of stringer rot.
Wood is an okay material but it will crush/sag over time. Better to use aluminum bar stock or a dense plastic material that will hold up better over time
OP found the rubber deteriorated on his front mounts in post #19
skisky89
Also the replacement mounts I ordered are actually shorter, not as tall.
My bad engine mounts look like this:
The new mounts look like this, and aren't as tall:
achris
More fish than mountain goat
You have fluid mounts, and you order the solid mount.
Fluid mount part number is -18098A3, but it's NLA from Merc. Some of the aftermarket shops might have something. or ebay.
Chris........
nola mike
Shouldn't OP have a balance shaft engine (didn't see a serial #)? Either way, mounts (and brackets, also a different p/n) are the same height.
achris
Yep, wonder if this is why we ask for engine serial numbers?
Chris..........
skisky89
I'll get back to you tonight with a serial number.
achris
The first number will be a 0, followed by a letter, then your 6 numbers.
Chris...
skisky89
Thanks everyone!
Vibration was resolved with replacement forward engine mounts, and I was in dire need of a new cap and spark plug wires.
On my test drive I lost power steering fluid. I took the pulley off the power steering pump in an attempt to save the pump for the ride back to the boat launch. I suspect the heat exchanger for the power steering fluid is the culprit, since the bilge is clean.
Rick Stephens
Chris, it looks like you've already been dealt with engine mounts from a previous thread. The mounts I bought maybe not be tall enough... Am I screwed? I've put them in... They may not be tall enough for me to align the engine. Maybe I can put a pressure treated 1-by between them and the boat?
Use aluminum plate for shim with holes drilled through.
