Hi, I have a mercruiser 4.3lx 1990. Loads of water in my oil and in cylinders 2, 4 and 6, and also number 3.
I originally thought it was riser/exhaust gasket so replaced those, but still have the same problem, so I took off the starboard head and there is a hole in the exhaust port of cylinder no.2 (see photo)
Question is, this would obviously cause water in the cylinders 2 4 and 6, but would water make its way over the intake manifold exhaust cross over into cyclinder no.3? And would this hole leak that much water into the crank case etc? I am hoping it would. The block looks OK in the valley with no visible cracks, so I am hoping that a couple of new heads will sort out all this water in my oil....
Thanks
Thanks
