Help with winterizing
Lake time
I have a 85 carver 26 foot the with no outdrive the motor is a murccruser 5.7 how do I winteriz with no out drive
Lake time
I live in northern pa last winter for a month it was -35? I really want to get a in the bock
wahlejim
Master Chief Petty Officer
Pull all of your plugs, take a wire and clean out the holes, let em drain! A common phrase around here... Air doesn't freeze!
Rick Stephens
If you want to run the motor, just stick your garden hose into the bellhousing water port - the one with the o-ring on it. It will run and cool perfectly.
pull all 4 plugs, poke the holes with a wire to remove the crud and drain the block and manifold. drain the power steering cooler of water
change oil and filter
winterized
http://boatinfo.no/lib/library.html
however middle of block on both sides, about 1" up from oil pan is a 1/4" pipe plug. pull those, then unfold a paper clip and dig around in there to make sure its not blocked by crud
bottom of the two exhaust manifolds about the middle or maybe on one end are the other plugs. pull those, then unfold a paper clip and dig around in there to make sure its not blocked by crud
what do you need the air compressor for?
relax, stay calm, drink a beer, pull plugs, poke holes, let drain. change oil, change filter (use a bag around the filter to catch the mess), spray out bilge with dawn dish soap, then rinse crud out of bilge.
the beer is to calm you down, the dawn dish soap is to help wash out the oil you just spilled.
no problem. we are here to help. Which carver do you have? a good friend of mine just sold his '88 Montego twin cabin.
Lake time
I got alot of red water and sand out the paperclip didn't work I used and air compressor to keep blowing the sand around
red water is rust. sand is normal for a raw water cooled boat that has been run in shallow water.
Lake time
One more question I have a big engine compartment and the oil pan has a drain plug I was going to drain the oil out the bottom but one little problem there is expanding fome under the motor blocking the drain plug I was going to drain it in to a tin pan but the foment is in the way what is the foment for its about 4 inch high by a foot long this is my first big boat
stonyloam
On marine engines the dipstick tube goes to the bottom of the pan, so you can suck the oil out from the top. There are a bunch of different pumps that you can purchase.
