Help
werdnlr
Anyone out there....I attempted to start my 1985 50hp evinrude. I primed, counted 8 seconds. It turned over but never started. I tried two different times, battery went really low, barely turned over the engine then I couldn't get the motor to stop turning over after I shut off the key. I took the cover off and found the starter still engaged. I finally had to disconnect the battery...I don't have a clue what happened
bgbass.1
Re: Help
try rechargeing battery some times starter will stick when batt.low
