Help
draft raft
Hi, I have a 1999 four winns with a V4 115 Hp Johnson outboard. I had the water pump replaced with the impeller,(not last summer, but the one before), and everything was good. I have small canal I have to go down to get to the lake(it's maybe 200 yards long), and in that 200 yards the engine temp gauge climbs to almost 220(which is the highest setting), and just before If it gets there, and I get to open water and take off, it immediately drops to about 125-130(where it should be) I've check the pee hole, because It's not a strong stream coming out,like it was with the new pump and impeller.It is not blocked. I then check the intake screens, and there is no debris.So 2 questions, 1) does this motor have themostats, and if so where are they located, and 2) is there some other thing that can be clogged either in the outdrive, or up inside the engine that I'm not aware of? please help, as I really don't have the money for a new impeller and pump. I appreciate any help anyone can give, and thank you in advance.
