Help
Seadogpdd
what prop will I use on 1982 sea ray amberjack 350 merc 26 horse 10 foot beam
welcome aboard
I assume you mean 260hp.
what drive is on there?
what is your current prop?
if you have none, you may need to borrow a test prop or two.
my first guess would be a 19P or a 17P as with a 10' beam, thats a big boat.
Ayuh,..... Welcome Aboard,..... The prop that allows the motor to run in the recommended rpm range, at Wot,......
