Here are the numbers off my prop!!
wilson750
I have a 86 Mercury 115 OB On a 19CC
48 77344A45 17p
I want to buy another prop and want to know if these numbers will tell me what prop to get!!
also is this a good size for what i have it on?
Thanks
Dhadley
Re: Here are the number off my prop!!
That's a 17" pitch. Yes, it's a good size if it puts the motor in the right rpm band and does what you expect with a reasonable amount of slip. It's not a good size if it doesn't. Very generally speaking I'd think a 17 on a 115 for a 19' boat would be reasonable. If you post the true speed and rpm we can figure the % of slip and see where you're at.
wilson750
Thanks Dhadley, I never took the boat out in the water yet!!! I was going to buy another one that is stainless!! I guess i should stick with that then!!
Unless you suggest a different pitch!!
Dhadley
If it were mine I'd not spend any $$ yet. I'd test and see where we're at. Then max out the set up with what's there and then buy a prop if needed.
wilson750
Yeah that is true, I just have one prop, the one that is on there!! And i need a spare prop!! With my luck i will take the boat out and the prop will go!!
Dhadley
Well, if it does it wasn't any good for a spare anyway. If it's in bad shape and you just need another one a decent 17 is probably the way to go. Got a few more specific questions / ideas - I'll shoot you an IM.
wilson750
Ok thanks for your help!!!
