here we go again
Gordo in the IE
just drained the lower unit on my 115hp #j115eledr and oil was all milky.oh had fishing line behind prop.do i just replace that seal and replace oil?????now what. thanks in advance
tashasdaddy
Re: here we go again
did you replace the seals on the drain & vent plugs, also?
jbjennings
Probably that is a yes but "just change the seal" is a pretty big "just".
You should probably pressure test it after you reseal it to be sure that is the only place leaking, but the fishing line is definitely a seal cutter. The prop shaft seal is just one of many that might be leaking.
JBJ
Gordo in the IE
im going to order some parts .Is that seal the most common culprit,or should i consider buying a complete kit......oh the breakdown is showing 2 seals behind the prop.
crxess
2 Seals is correct. watch which way they go in. One keeps water out. the other keeps oil in.
lindy46
Probably not much more money to buy the whole seal kit - then you have them if you need them.
karlow1
You might consider replacing the water pump while you are in there.
KP
FBPirate95
I ditto the fact you need to pay special attention to the direction of the seals and any other parts you pull out. You'll kick yourself later if you don't.
