Re: Here We Go: My 383 Stroker Winter Project
Air flow is a tricky thing, very much a science. Ive seen many botched porting/ gasket match jobs come into the shop i worked at. While i agree that improvements can be great, a vortec is already pretty good as is. Id let it be. I have a set of fully worked iron heads (041 castings,non vortec) that i did myself (flow bench) and i will never do another, its a long process.
As to the stud, I would call ARP and ask if they have a non hex base stud specifically for vortec castings. I bet most people use the hex base and guide plates (drill out the pushrod hole) that way you can keep from buying the more expensive self aligning rockers. Remember you have poly locks that fit the factory vortec thread right now, so you need a stud that is the correct height, same top thread if possible, correct bottom length/dia/thread pitch. ARP is a very good brand, its been years sense i called them but they were pretty smart back then. They did their own R&D work, I bet they still do.
Its good you don't have pinned studs, i my opinion it ruins a set of heads. Weakens the casting and they cant ever be converted to screw in.
Be patient, do your homework, don't get bummed out by set backs, its part of the process.
