greg82255
Thread starter- Joined
- Oct 26, 2009
- 781
Re: Here We Go: My 383 Stroker Winter Project
Yea I'm pretty much doing the same but slightly less dramatic of a change - went from a 260 hp 350 to this 383 with an aluminum intake and exhaust which will hopefully be somewhere around 400hp. If anyone has made the switch to aluminum and noticed the weight difference, please post your experience. I assume the boat may sit slightly higher with 100lbs less in the back. I've actually considered also moving the batteries to get more weight out of the back, but there's no good place for them. .
I've actually been told not to run the engine anymore out of the water. A few guys posted here that the engine should be turned on, immediately put in gear and put above 1500 rpm right away because it's not broken in yet. I'll post a picture once I get it done - should be by next Monday or Tuesday - school is out for the summer one week from today so I'll get right on the boat when I'm home.
Im not a good test case for the weight question. Because I went from a 200hp Mercuriser 305, to a 383 with the aluminum intake and exhaust. So, my power was way different. (I wanted Aluminum Heads, but didnt get them because Patriot Performance sold me cast ones for for a great deal because they had been ran on a Dyno test engine)
Youll be able to tell in 10 min in the driveway if you hooked it up incorrectly. The rubber hose to the exhaust tips will get HOT.
