1970 evenrude 40 hp runs fine in idle and at half throttle but when open up to wot the motor hesitates and shakes back and forth for a few seconds and then takes off and runs fine not sure if this is carb problem, timing or maybe the fuel pump.
F_R : Could you suggest a good manometer/carb sync gauges (or whatever is needed) setup for this process? I have a 2000 90 HP 4 stroke mercury.
