Re: Hesitation during plane-off
Greg, I can make a couple suggestions but can't answer all.<br />Most likely you need the rebuild kit.. they are cheap, and it's likely you will tear gaskets and stuff when you disassemble a carb. Don't take shortcuts and you won't have to do the job twice.<br />Outboard carbs are famous for getting gummed up, mostly from being left sitting with fuel in them.<br /><br />A fuel filter change is also cheap insurance... if you don't know when it was done, change it and now you do.<br /><br />You really ought to get the manual for that motor.. you can buy it right here on I boats and it should be the very first thing you do, before you start tinkering with it... study it and become familiar with your motor and you will have a lot more fun and a lot less hassle when you do proper maintenance. The book will also contain the specs to answer your other questions.<br />There are no online service manuals that I am aware of.<br /><br /><br />Best of luck<br /><br />Craig<br /><br />,
