hey j.b. cornwell
bremp1
i tried checking out the dead cylinder the cylinder does have compression and spark , do you have any other suggestions on what to check next maybe the carb?
JB
Re: hey j.b. cornwell
Yep. Carb and reeds. Carb can be foolproof tested by swapping. I don't think the reed plates will interchange but you should be able to check the reeds by eyeball. They should seat flat against the plate and lift off easily, no sticking, no gum or varnish. <br /><br />Good luck.<br />JB
