DukesFin
- Joined
- Oct 12, 2005
- 500
Found the plastic washers for my OMC 165 Stringer (1973)- (slow to shift into Forward) and you were right on about the price. What I need to know is if I am interpreting the manual correctly. I need to remove the outdrive, remove the swivel housing, exhaust housing, THEN the lower unit???<br /><br />After I do all that, I need to basically dismantle the whole shaft assembly (prop shaft) along with the needle bearings to replace the plastic washers?<br /><br />Please tell me I'm not correct in this. I will have no problem dismantling, but putting everything back together worries me. If I'm correct in my interpretation, is it as hard as it seems to one who is "mechanically inclined". I found that replacing the seals in my intermediate housing pretty easy (and I was worried before hand).<br /><br />Thanks for any help here.
