Hi Idle screw
SweeperForce
Hello,
I was told in here if I want to lower my idle there is a screw adlustment. The only screw that makes sense is the one with the arrow pointing to it in the photos I attached. With this lower my idel speed?
Thanks,
Tom
Mark9740
Re: Hi Idle screw
Sweeper Force,
I had to figure this one out too. From your phto, if you follow that rod down to where it has a smaller rod attached to the carb cam, there is an adjustment screw with a locking nut to the left of it back against the block. I don't have my manual out or I'd give you the correct name.
john from md
Re: Hi Idle screw
DON'T TOUCH THAT SCREW! If you do, you will screw up your timing. As Mark said, follow the timing tower down and about midway you will find a screw with a locknut. The screw itself is pushing against the engine housing and is usually stainless steel with a common slot.
John
SweeperForce
Re: Hi Idle screw
Ok, I think I found the screw. I'll post a picture of make sure I found the right one. Thanks for all the help.
john from md
Re: Hi Idle screw
Yep that's it. Don't forget to tighten the nut after you adjust it.
John
