I haven't experienced this but I am curious. I've heard many comments that some of these 2-strokes can "runaway" in neutral and that's the reason for the vacuum shorting switch for one set of points.<br /><br />The only way I could imagine this, is for the revs to get so high that the crankcase vacuum is able to override the throttle return spring and pull the butterfly open. At that high vacuum, it also pulls in the diaphragm on the override, shorting one set of points. Is this correct?
