garbageguy
- Joined
- May 8, 2012
- 1,598
The little electric "hidden horn" on 1998 Wellcraft 240SE was weak when I got the boat about 7 yrs ago. Since last yr, no sound at all. Assuming the little horn reached end-of-life, bought a replacement Attwood horn for about $10. Before removing old horn, pulled wires, getting 12-volts through the wiring when switch on dash is rocked on. Put the wires to the new horn, got a little sound - figured the temporary test connection not so good. Before I remove old/install new horn, I want to make sure the new horn works - should it sound if it gets 12 volts, maybe a quick touch of the 2 wires to a known 12-volt source?
