High Five 21" Should Change or Re-Pitch? Does PVS make a difference?
Mick_QCD
376582_2523580482289_1036661729_32740340_1530618480_n.jpg400266_2695993592509_1036661729_32804683_430020517_n.jpg407202_2695998632635_1036661729_32804696_516339443_n.jpg
Hey Guys,
I currently have a a high five 21P on my 2011 Bayliner 185 with a 220 MPI
While out yeterday with 7 people + gear + full of fuel it was struggeling to pull a single skier out of the water
when i got the boat the PVS on the prop were plugged up.
Do the vents on the prop make a big difference?
Should i option a different prop? pitch? or have my prop re-pitched if possible?
etracer68
Ensign
Re: High Five 21" Should Change or Re-Pitch? Does PVS make a difference?
You will need to get a prop for that load, I would try a 17p, and watch WOT rpms. I have three differant props for differant load and lake conditions, and will put the prop that works best for that condition.
tpenfield
Yup, a high five 21" P is probably not a good choice for a 220 engine. If you plan on having that amount of load frequently, then think about a 4 blade with a 19" pitch or something in that range. If you know what the boat came with originally, that would be a great help, as a reference point, as the manufacturer usually puts the best 'all-round' prop on the boat.
Are those all your friends in the pictures?
Ayuh,... Leave some of yer friends on shore,...
Yer Over-loadin' the boat, 'n still expecting performance,..??
