I have a 91 Evinrude 48 special and have been using high test fuel. The engine has run well so far with maybe 200 gal of fuel used this summer. I run the high test because no one sells regular ethanol free gas near my house and I have had problems ( carbs needing rebuilt or replaced and fuel lines needing replaced) with other two cycle engines like weed eaters and chain saws which were solved by using non ethanol fuel. Any thoughts on if using high octane gas is bad in the long term for this engine or any thoughts on the use or non use of ethanol added gas in outboard engines. Thanks in advance for any thoughts on these issues.
