High oil presure
Goat1314
1989 4.3L 262 Mercruiser V6 2 barel
SO I installed a new head on my engine, put everything back together. Took it our for a spin and my Oil Presure is 6opsi at idle and goes up to about 75 or 80 at 3000rpm. THis is much higher then the Manual#7 says it should be
THey specify no less then 4psi at idle and no more then 45 to 55 at 2000rpm
I put new plugs In it
Tested the compression at over 150psi on all pistons
Droped a can of Seaform in the oil
Yesterday a cuople of times the pressure at idle after planing would drop to 40psi and bounce around then go back to 60psi
My question is how worried should I be. do I let the Seaform do its bit for a while... DO I pull the engine out and rip apart the oil pump... Is it just some crap in there that will work itself out eventualy??
Is such a high oil pressure uncommon anybody else out there run the same engine and what is your oil PSI at ??
Thanks guys
Goat1314
Re: High oil presure
Also I should mention that I cracked the head because the engine overheated and I had water in my oil that made a milkshake.I have since put a new oil filter and changed the oil (obviously) should I change the oil again??? What about dropping the oil from 25W40 to 10W30 or 5W20?? would that help to clean out the engine?
04fxdwgi
Some causes of oil pressure jumping up:
1. Most probably (since you stated it dropped, then bounced up again): Stuck relief valve in oil pump (could have crud in there making it stick)
2. Bad sender
3. Spun cam bearing / plugged oil passage
4. Oil too thick
Change oil / filter again with high detergent oil of a lighter weight, run it for a while and change oil / filter again and see what happens.
Have done this before and added a pint of transmission fluid (which is has extremely high detergent content) to the oil. Run till warmed up, then change oil. Really cleans the engine insides.
Goat1314
So I tried the Seafoam detergent and changed the Oil to 10W30
I've noticed that At low RPM like when I'm trolling we get a little blue smoke. Almost like I'm burning OIL. I'm keeping a close Eye on the Oil level of course. could the lighter oil be the culprit. Are Marine engine just a looser fit on the O-rings... is that why they use a thicker Oil (25W40) It didn't help much with the oil presure. That's down to 70 PSI at high RPM and 40 to 60 at low RPM.
