high speed fuel orifice size??
ride1216
can anyone tell me what size the high speed fuel orifice is on a 2000 150hp johnson v6? or is there not suppose to be one in the carbs? i pulled all 6 carbs off and i see where the threaded area is in the bottom of the bowl for the jet but there isnt any in there. is there suppose to be some in it?
ezeke
Re: high speed fuel orifice size??
Each float bowl should have a high speed jet behind the drain plug.
There are many models of J/E 150HP in 2000, each with its own specifications. If the carburetors are the originals, you can find the correct orifice size in the carburetor parts diagram listing for your specific model here: http://evinrude.cust.shopatron.com/
