Re: High Speed Problem. Not sure of cause
You should be able to remove/clean the jet with the carb mounted, look at #35 below. remove the plug and the jet is located about 1" behind the plug.
http://www.ishopmarine.com/ishop/js...CatFilter=BRP&eCatSupFldr=supplier-100-005-EJ
