High Speed RS232 - 230Kbps
Mark42
I see some com1 ports on PC's have a choice of speeds up to 230Kbps. My Win XP PC (Dell Dimension 8250 from March 2003) has speeds up to 128Kbsp listed in Device Manager under Port Settings. <br /><br />Anyone know how to get 230Kbps? Is it a driver update? Tried that but the wizard said there is no better choice than the driver I have.<br /><br />Even the RS232 on my router goes up to 230Kbps, so why not the PC?
Xcusme
Re: High Speed RS232 - 230Kbps
You're looking at the limitations of your MB hardware. The onboard UART is what controls your serial speed. You have 2 options, replace the MB or buy a PCI Serial card with faster serial ports.
Mark42
Ahhh, I was afraid of that. While searching for drivers I found some PCI cards with high speed rs232 ports. That was my first clue that it could be hardware. <br /><br />Thanks for confirming my suspicions. I've made a change in my hardware so I won't be using the com1 port. But it's good to know for the future.<br /><br />Thanks,<br /><br />Mark
