High Tension Leads (spark plug) 1968 9.5
jeff_smith_0423
I'm redoing the entire ignition on a new-to-me 68 'Johnson 9.5 The original wires are shot. The assembly is OMC 0580186. I'm not having any luck sourcing them. I tried to make my own leads with modern spark plug wire but can't get a spark through them (carbon graphite cores?). I've been to five different shops and can't source the copper wire. What's the solution?
James R
Re: High Tension Leads (spark plug) 1968 9.5
OMC made plug wire kits for most models. A good dealer should be able to find what you need.My dealer may have the items in stock or can get them. Info@couicksmarine.com. He owns a 9.5 as I do and he has had two before that. Great little motors.
jeff_smith_0423
Yeah, unfortunately it is a "dealer direct" part and BRP doesn't list anyone in my state that has them. I'm guessing i'm going to have to make a set - which shouldn't be a big deal, i just can't source the proper wire.
Sea18Horse
Laings outboards sells them. p/n SPW1. Unfortunately (or not) the spark plug boots on those are bright blue :rolleyes: . I found some 7mm copper core spark plug wire at the local Car Quest store (bright yellow :eek: ). Find an auto parts store that caters to the hot rod crowd. They'll be more likely to have it than your local Napa store.
That said, I can't believe they're that hard to find at the local outboard dealer, although I've never actually tried to look. I just assumed every dealer would have a roll on hand. It'd be like an automotive repair shop not stocking oil filters!
Cheers................Todd
iwombat
Napa generally has solid core wire (you don't necessarily need copper core).
jeff_smith_0423
Yeah, I'm not too concerned about color, just have to be able to move a spark. NAPA and Carquest sent me to our local lawnmower shop, who just sort of laughed. Unfortunately none of the marine stores i trust were open long enough to get out there. I'll have to try later in the week or order them. Sorta bummed since i waited until friday night to replace the coils, condeners and points. If i started earlier i would have been able to find something that would work this morning.
Has anyone had any luck rigging the newer stranded core wire? I'm just irritated that I bought it at this point.
iwombat
*slaps forehead*
I meant metal core wire above.
Stranded is what will come in the OEM kits.
steelespike
Here at iboats sierra 18-5225 plug wire kit.listed for Johnson but same as Evinrude.
joho5
I just went to the local parts store and got regular spark plug wire and boots and did my own. It works like champ.
I am not sure why the ones you picked up at napa wont work. All they do is screw onto the coil, well at least the Sierra brand coils.
jeff_smith_0423
Maybe something else is amiss, but I certainly tried. The wire I was able to get has a very thin, fiber core. I think it's made of graphite or some sort of carbon strand. Neither store had anything with a metallic core in store. I assembled the wire and boots and wasn't able to get a spark at all. Maybe someone who's tried this can comment. I've ordered metallic core wire with the boots pre-installed. i won't be able to screw that one up, for sure.
iwombat
For future reference - british bikes use metallic core wire too. Maybe there's a shop near you.
