Can a larger outboard that hit a rock and damaged the prop and prop shaft make the prop come while limping back in to shore? There was a bit of vibration and I was wondering if that is what caused it. The prop does not have a locking key pin.
There are only two ways to lose a prop. 1) Prop nut comes off and the prop slides off when you cut the throttle, or 2) if the prop shaft breaks in which case part of the shaft snaps off taking the prop with it.
Without going outside to look at my prop, can you 'spin' the prop enough to lose it, and have the prop hub still in place on the shaft?
Just wondering....
