SS MAYFLOAT
- Joined
- May 17, 2001
- 6,372
Rebuilding my hitch. I have a pin that I picked up from Tractor Supply. It is a hitch pin used to hook up implements to the tractor. I feel this pin is what I need, but a few friends said they weren't sure if it is hard enough. I called the store and asked them if they new it was hardened or not. They didn't know.<br /><br />The pin is 3/4 diameter by 6 inches long. I could make one out of a grade 8 bolt, but I want this to look professional. It also needs to be easily unpinned/pinned. I don't want to be getting the wrenches out to remove and replace the pin each time I load/launch my boat.<br /><br />So shouldn't I be safe with this drawbar pin?<br /><br />Note: this pin is not the primary pin to hold the receiver into the receiver tube. This pin will go through the receiver & tube to lock in my vertical height adjustment.
