Steven_C17
- Joined
- Jun 22, 2002
- 10
Hello !<br /><br />Well I am just getting ready to obtain the underbody hitch for my car.<br /><br />I have a thundderbird LX 1996. It has been mod with a oversized air chip, a special change to the back and a few other mod's.<br />Was already setup that way as the other owner was going to toe,
<br /><br />but either removed the toe package or never had it installed.
<br /><br />I am a bit concerned on a bit of info I am not sure about.
<br /><br />First the book said the car can handle 2000 LBS, and a 200 frount load. I was informed by a ford tech that the changes made will handle 2500, 250 respective.
<br /><br />Ok on the hitch I heard from a few friend that they had some problems with special packages from U-haul and other places they had made. Would it be best to stay away from these places or not ?
<br /><br />Next what maker/model would be go for a frame under body package ?
<br /><br />Next is should I install ro have it installed as I never hooked up a toe system on a car before ?<br /><br />Also should I have the wiring down bya expert or installed ?<br /><br />As noted I am planning on a 14' to 16' boat. Most likly will be one of the firbeglass light weights used with a trailer. Total weight should not execed 2,500 fully loaded down.<br /><br />Any suggestion and help would be helpful and I thank you in advance !<br /><br />
