hole on the rear end right side of the boat, speaker mount
rzkas
hi? i have a 95 bayliner capri ls. it has a hole or outlet on the rear right side of the boat. the hole has like a white plastic around the hole. what is that hole for? i mean it purpose?.
how many hours can i get from a full tank?
where is the best location on this boat to mount speakers and what size speakers will be good to install?
brand and size speaker suggestion pls.
thanks
Capri90
Re: hole on the rear end right side of the boat, speaker mount
Hey.
1.The hole -if we mean the same- is from the bilge pump.
2. depends on motor and what you use it for. (waterski or fishing for example)
3. I have mine in the sidepanels.
4."Jensen Marine" about 6.5"
Hope it helps
oldjeep
Don't you have speakers? The stock ones on the side panels of a bayliner are 5.25". I've got an extra pair of 6.5's mounted in boxes that are mounted on the shelves under each console. Mine are all Cadence Marine
rzkas
yes i do have the 5.25 but i want to add another speaker
oldjeep
You've got a couple options. Some folks cut holes in either the side panels of the consoles or the bow seat bases. You can mount them under the dash like mine - didn't want to cut any holes. Could also put a pair on the sides up by the front seats, but they would need to be down low to be out of the way of the controls on the driver side.
rzkas
hi and how are you? pls send me pics of you boat and locations you mount your speakers. i see a pic of you wakeboarding or sking. i have never done this i want to ski this summer. i have skies already. pls give me technique and tips on sking. i am beginer. i want to ski and wakeboard this summer. thanks
