Holley carb ID help needed.
PaulMyles
Hi there, I have a 2002 Glastron with a 4.3 GL-A. I'm trying to find a carb kit, but can't figure out the numbers. Any help would be appreciated. It's a Holley 2 barrel and I believe a 2300.
Choke tower 3858330, 75006-1, 2631
On top, on the spark arrestor mounting plate 6R 3250 B
On mounting base 12R-3975B
jimmbo
From a Volvo Service manual. The carbs spec, but no carb kit number, yet
4.3GL-A Models
Volvo Penta #3858330 500 CFM Model 2300-2V
Pump Lever Clearance. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.010-0.015 in. (0,254-0,381 mm)
Choke Unloader . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3/8 in. (9,525 mm) Measured Lower Edge of Plate
Choke Setting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Notches Lean
Initial Idle Mixture Setting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5/8 Turn Off Seat
Main Jet . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 70
Power Valve . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.5
Float Setting . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Parallel to Fuel Bowl When Bowl Inverted
Choke Vacuum Qualification . . . . . . . . . . . . . . . . . . . 0.250 in. (6,35 mm) Measured At Lower Edge of Plate
Pump Cam Position (red cam) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . No. 1 Hole of Cam and Throttle Arm
edit: Volvo Penta parts website doesn't allow non US IP addresses to access. So I couldn't get the carb overhaul kit number from Volvo
Holley website shows Renew Kit
703-30, for all their 2bbl marine carbs
