AaronWhitt82
- Joined
- Sep 22, 2007
- 54
Hey guys..... Once again it's that time to get the boat out of storage and do the whole de-winterization process and check everything over on the motor and get the ol Holley tuned up....
At the end of last year the carb started acting up on me once again. I believe it has something to do with the air/idle mixture screws and possibly the secondary speed screw.
I am finally going to invest in a vacuum gauge from my local JC Whitney so I can get the air/idle mixture screws set exactly where they need to be.
Here is the link for the vacuum gauge:
http://www.jcwhitney.com/vacuum-gaug.../p2008137.jcwx
Basically the boat was idling a bit high and I had the idle screw pretty much backed all the way off and it was still idling just around 900rpm's (not in gear)... This might have something to do with where the air/idle mixture screws were set because I just kind of guessed where to set them or maybe even the secondary speed screw...
Now this secondary speed screw is what confuses me... I'm not quite sure how to adjust it. I rebuilt the carb back in the Spring of 08 and I do not remember what I set this screw at....
Here is a link for the secondary speed screw:
http://www.youtube.com/watch?v=__3ruSX8Q_A
Also if I am understanding this correctly the idle screws need to be adjusted the same amount on the primary and secondaries so the throttle plates are opened the same amount???
After never working on a carb before in my life; I now pretty much know the Holley 4150 inside out, how to disassemble everything, rebuild it, adjust everything and how it all works. This is the only thing I am a bit confused about....
(All the info for my boat is in my sig)
Thanks
Thanks
