Hollow stringers on 28' cabin cruiser.
rs2k
Is it common to have fiberglass only stringers on larger boats? The only wood on my boat appears to be in and around the engine area, everything else is fiberglass. I first noticed when I took the boot off the stringer drives. The only supporting wood other than the 2 inch thick transom appears to be a simple 2x6 that is used to hold lag bolts and to help sandwich the top of the fiberglass stringer to the bottom of the motor mounts. I followed the stringers all the way up front, there is no wood, just fiberglass.
My 17' outboard tri-hull has nearly all wood stringers, my 18' tri-hull with a stringer has fully encased wood stringers, while this 28' cabin cruiser has very little wood.
