Augoose
Thread starter- Joined
- Mar 21, 2010
- 1,245
I've got a '99 volvo penta 5.0 GLPLWTR which according to Holley, has a 2300 series marine carb. I recenly purchased renew kit 703-36 which Holley advised was for the carb based on the stamping.
My question pertains to the pump discharge check ball. During my dissasembly, there was no ball in my carb however the renew kit plus the instructions both come with and list the ball as necessary. My problem is when I install the check ball, then the pump discharge weight, then the pump discharge nozzle and screw, its physically not deep enough for the screw to reach the threads. If you remove the ball, it screws down just fine.
Can someone verify if I need the pump discharge check ball which is number 89 in the schematic?
Thanks
Thanks
