holsclaw trailer suspension
Andy in NY
my most recent project boat is on a holsclaw trailer with dual coil spring and shock on each side. the trailer seems to bounce ALOT, and i was wondering if i can replace the shocks that are on it with something a bit stiffer?
NYBo
Re: holsclaw trailer suspension
If the shocks are old, replacing them with new ones of the same rating may be enough. You don't want the suspension so stiff that more of the road shock is transmitted to the hull.
Andy in NY
where can i find them? internet searches havent turned up much...
woosterken
Andy,
check your PM hope this helps
woosterken
Ryanmolnar55
I've ran into the same issue with my Holsclaw trailer did you end up figuring it out? if so any info would be appreciated.
tpenfield
Old thread alert. You should start a new thread for best results.
