pete44
Thread starter- Joined
- May 7, 2005
- 189
Seen dozens of posts on going to use pink or blue styrofoam insulation to use instead of pour in foam...I have seen comments on "allowing drainage" to bilge area instead of foam that "blocks" drainage...Who out there has a method of installation of the foam sheets that "allow drainage" through contained areas?....Also, I read you can use the pour in foam but place a plastic cover before it meets hull that way the pour in foam never meets the hull thus leaving a gap for water/moisture to drain...Problem with the factory foam which many of us know it meets and bonds to hull and when I removed it it looked "dry" until I pryed it from hull (then wet underneath)....Opinions please
And lastly, How do you make your thread title in bold letters on this forum?
Thanks,Pete
Thanks,Pete
